Phone ok, PC not ok???
I can connect to my home PC using my Android phone app but when i connect using my PC in work it says "please wait for your partner to confirm the request"
I am convinced the settings are correct on the PC to provide full access and anyway if they werent then why can I connect with my phone.
Ok I have just figured it out so for anyone else who runs into a similar problem...
On the remote computer you need to have full access under the 'Access Control' setting for advanced settings for connections to this computer. Which I did have set and therefore couldnt understand why it prompted me to wait for a user to authorise.
What I didnt have set and didnt know and seems a bit odd is that on the PC you are using to connect to the remote computer under Advanced but this time "Advanced settings for connections to OTHER computers" you also need to have Full Access selected under "Access Control"
1
