Teamviewer is trying to install a helper tool
A dialog box with "Teamviewer is trying to install a helper tool" keeps appearing on my remote mac. Entering an admin id and password resolves the issue if you are in front of the computer, but it stops you from accessing the computer remotely.
Does anyone know how to fix this?
Find more posts tagged with
Sort by:
1 - 19 of 191
    User: "MoreCoffee"
    Staff member
    Accepted Answer
    Updated by MoreCoffee
    @RJG1999 This message can occur if the version of the helper tool that is installed does not match the version and/or product of TeamViewer that is attempting to talk to it.
    This can happen if you have multiple different versions of TeamViewer on your Mac, or if you moved TeamViewer outside of its standard location in Applications. It can also happen if the TeamViewer app you have installed has been damaged.
    To fix this:
    1. Download the most recent version of TeamViewer from the official download page (if you are using TeamViewer Host, download that).
    2. Install it (no need to uninstall before). TeamViewer should come back up just fine, but I'd still recommend doing this with physical access to the machine, just to be 100% safe.
    3. TeamViewer should now be up and running again normally, but don't stop yet.
    4. Locate any other copies of TeamViewer that you may have on your Mac. Please delete those (or archive them some place where you won't accidentally open them). There should only be a single TeamViewer or TeamViewer Host app remaining on your Mac, and it should be located in your Applications folder.
    Let me know if this helps :)
    @Max_L2z It sounds like your Mac might be taking unusually long to validate code signatures.
    Could you please send the output of the following command:
    log show --last 2d --style=compact --predicate="subsystem='com.teamviewer.Helper'"
    You might want to use a different value than 2d (= 2 days) in case there is a lot (or very little) output. Make sure you do include the time when the problem last occurred.
    There should normally be no personally identifying information in the output (but do check it quickly before you post it here, just in case).
    Also, could you please try the following command:
    /usr/bin/time -h codesign --deep --strict --check-revocation -v --verbose=5 /Applications/TeamViewer.app
    It might take several minutes to complete and you'll see several dozen lines of output (feel free to switch to another app and continue working while it is running).
    At the end, it should print some timings similar to:
    	0.84s real		0.92s user		0.58s sys
    What values are you seeing there?
    Also, in case this completes fairly quickly (seconds, not minutes), could you please try the same command again after a restart of your Mac to see if there is any significant difference?
    The reinstall seems to have done the trick. I really appreciate the help. Thank you all.
    @Max_L2z Apologies for not being more specific. In Finder, go to Applications -> Utilities. You should find Terminal there, double-click it to open like you would any other app.
    In case you have used the Windows command prompt before, Terminal on macOS works very similar.
    Type the command in the Terminal window, exactly as written above, including capitalization and quotation marks. You can also copy & paste them, if you prefer.
    Once you have typed the command (the entire line), press the return key on your keyboard to run it.
    For the first command
    you should see output immediately if you typed it correctly. The output should look somewhat like this:
    Filtering the log data using "subsystem == "com.teamviewer.Helper""
    Skipping info and debug messages, pass --info and/or --debug to include.
    Timestamp Ty Process[PID:TID]
    2021-12-14 15:19:26.148 Df com.teamviewer.Helper[53030:ab0de] [com.teamviewer.Helper:-P0-3] Dynamic client validation passed.
    2021-12-14 15:19:26.956 Df com.teamviewer.Helper[53030:ab0de] [com.teamviewer.Helper:-P0-3] Client is located in /Applications.
    This is the output I would like to see. You can select the text of the output in Terminal and copy & paste it here.
    For the second command
    it might actually take a few seconds until you see the first line of output. It will look somewhat like this:
    --prepared:/Applications/TeamViewer.app/Contents/MacOS/TeamViewer_Desktop_Proxy
    --validated:/Applications/TeamViewer.app/Contents/MacOS/TeamViewer_Desktop_Proxy
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVDiagnosticDataReporting.framework/Versions/Current/.
    As I said, this might take quite a while on your Mac, but probably not longer than 15 minutes. At some point you should see something like:
    /Applications/TeamViewer.app: valid on disk
    /Applications/TeamViewer.app: satisfies its Designated Requirement
    1.21s real 1.01s user 1.11s sys
    I'm primarily interested in the first number ("1.21s real").
    I was going through your Post regarding the Installing Helper Tool situation as it is one that I have been dealing with for some time and are experiencing the same exact issues (every time I restart I have to do the Helper Tool Twice)!
    I saw you submitting log information, but then it fell off there. Were you able to get a resolution??
    Hello MoreCoffee,
    I restarted my office iMac as you suggested and retyped in the second command and here are the results:
    --prepared:/Applications/TeamViewer.app/Contents/MacOS/TeamViewer_Service
    --validated:/Applications/TeamViewer.app/Contents/MacOS/TeamViewer_Service
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVNoteIntegration.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVDiagnosticDataReporting.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionMeeting.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVNoteIntegration.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionMeeting.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionSendFileViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionSendFileViewModels.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVAutoupdate.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVAutoupdate.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUIPreferencesViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUIPreferencesViewModels.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUIPartnerListViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUIPartnerListViewModels.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVOSPermissionsViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVOSPermissionsViewModels.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVQuickLook.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVQuickLook.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUIMeetingScheduler.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVCoreUI.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUIMeetingScheduler.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVCoreUI.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVOSPermissionsUserInterface.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVOSPermissionsUserInterface.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionFileTransferViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionFileTransferViewModels.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionRemoteSupportViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionRemoteSupportViewModels.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVSpeech.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVSpeech.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionBaseViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionBaseViewModels.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionPilotViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionPilotViewModels.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/Sparkle.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVDrawing.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVDrawing.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVFoundation.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVFoundation.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/Sparkle.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionPilot.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUIBaseViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUIBaseViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionPilot.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUIAccount.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVSystemMonitoring.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVSystemMonitoring.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUIAccount.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUICreative.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUIChatViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUIChatViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUICreative.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionMeetingViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionMeetingViewModels.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUIMainBaseViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUIMainBaseViewModels.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVPrinting.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVPrinting.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionPlayer.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionPlayer.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUIMainBase.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVCrux.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVCrux.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionPlayerViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionPlayerViewModels.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUICreativeViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUICreativeViewModels.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUIPartnerList.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUIPartnerList.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUIMainFull.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionRemoteControlViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionRemoteControlViewModels.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUIMainFullViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUIMainFullViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUIMainBase.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUIMainFull.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionSendFile.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionSendFile.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUIPreferences.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionRemoteControl.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVLogging.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVLogging.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUIWidgetsViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUIWidgetsViewModels.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUIMeetingSchedulerViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUIMeetingSchedulerViewModels.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUIWidgets.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionBase.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionBase.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUIWidgets.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionRemoteControl.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUIPreferences.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVAVFoundation.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVAVFoundation.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUIBase.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVMetal.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVMetal.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUIChat.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionFileTransfer.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionRemoteSupport.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVOSPermissions.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVOSPermissions.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Frameworks/TVUIAccountViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUIAccountViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUIChat.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUIBase.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionRemoteSupport.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Frameworks/TVUISessionFileTransfer.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Helpers/Restarter
    --validated:/Applications/TeamViewer.app/Contents/Helpers/Restarter
    --prepared:/Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Desktop.app
    --prepared:/Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Desktop.app/Contents/Frameworks/TVSystemMonitoring.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Desktop.app/Contents/Frameworks/TVSystemMonitoring.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Desktop.app/Contents/Frameworks/TVLogging.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Desktop.app/Contents/Frameworks/TVLogging.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Desktop.app/Contents/Frameworks/TVOSPermissionsViewModels.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Desktop.app/Contents/Frameworks/TVOSPermissionsViewModels.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Desktop.app/Contents/Frameworks/TVOSPermissions.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Desktop.app/Contents/Frameworks/TVOSPermissions.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Desktop.app/Contents/Frameworks/TVFoundation.framework/Versions/Current/.
    --validated:/Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Desktop.app/Contents/Frameworks/TVFoundation.framework/Versions/Current/.
    --prepared:/Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Assignment
    --validated:/Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Assignment
    12.89s real 0.99s user 0.42s sys
    I look forward to hearing from you soon,
    Kind regards,
    Max
    Hello MoreCoffee,
    After typing in the first command, here are the results:
    2021-12-15 07:03:09.741 Df com.teamviewer.Helper[745:25f4] [com.teamviewer.Helper:-P0-3] Dynamic client validation passed.
    2021-12-15 07:11:47.472 Df com.teamviewer.Helper[745:25f4] [com.teamviewer.Helper:-P0-3] Client is located in /Applications.
    2021-12-15 07:11:47.472 Df com.teamviewer.Helper[745:25f4] [com.teamviewer.Helper:-P0-3] Static client validation passed.
    2021-12-15 07:11:47.485 Df com.teamviewer.Helper[745:25f4] [com.teamviewer.Helper:-P0-3] Connection invalidated, exiting.
    2021-12-15 07:45:18.784 Df com.teamviewer.Helper[61599:2eaec] [com.teamviewer.Helper:-P0-3] Dynamic client validation passed.
    2021-12-15 09:03:59.278 Df com.teamviewer.Helper[63002:4ec81] [com.teamviewer.Helper:-P0-3] Dynamic client validation passed.
    2021-12-15 09:05:33.052 Df com.teamviewer.Helper[63002:4ec81] [com.teamviewer.Helper:-P0-3] Client is located in /Applications.
    2021-12-15 09:05:33.052 Df com.teamviewer.Helper[63002:4ec81] [com.teamviewer.Helper:-P0-3] Static client validation passed.
    2021-12-15 09:05:33.066 Df com.teamviewer.Helper[63002:4efff] [com.teamviewer.Helper:-P0-3] Connection invalidated, exiting.
    2021-12-15 09:20:46.475 Df com.teamviewer.Helper[800:35b1] [com.teamviewer.Helper:-P0-3] Dynamic client validation passed.
    2021-12-15 09:31:55.938 Df com.teamviewer.Helper[800:35b1] [com.teamviewer.Helper:-P0-3] Client is located in /Applications.
    2021-12-15 09:31:55.938 Df com.teamviewer.Helper[800:35b1] [com.teamviewer.Helper:-P0-3] Static client validation passed.
    2021-12-15 09:31:56.235 Df com.teamviewer.Helper[800:4701] [com.teamviewer.Helper:-P0-3] Connection invalidated, exiting.
    2021-12-15 10:19:09.089 Df com.teamviewer.Helper[2696:191ae] [com.teamviewer.Helper:-P0-3] Dynamic client validation passed.
    2021-12-15 10:26:40.555 Df com.teamviewer.Helper[2696:191ae] [com.teamviewer.Helper:-P0-3] Client is located in /Applications.
    2021-12-15 10:26:40.555 Df com.teamviewer.Helper[2696:191ae] [com.teamviewer.Helper:-P0-3] Static client validation passed.
    2021-12-15 10:26:40.569 Df com.teamviewer.Helper[2696:191ae] [com.teamviewer.Helper:-P0-3] Connection invalidated, exiting.
    2021-12-15 10:33:18.649 Df com.teamviewer.Helper[3291:1f579] [com.teamviewer.Helper:-P0-3] Dynamic client validation passed.
    2021-12-15 10:33:19.415 Df com.teamviewer.Helper[3291:1f579] [com.teamviewer.Helper:-P0-3] Client is located in /Applications.
    2021-12-15 10:33:19.415 Df com.teamviewer.Helper[3291:1f579] [com.teamviewer.Helper:-P0-3] Static client validation passed.
    2021-12-15 10:33:19.428 Df com.teamviewer.Helper[3291:1f579] [com.teamviewer.Helper:-P0-3] Connection invalidated, exiting.
    2021-12-15 14:26:20.898 Df com.teamviewer.Helper[5924:7755e] [com.teamviewer.Helper:-P0-3] Dynamic client validation passed.
    2021-12-15 14:27:10.481 Df com.teamviewer.Helper[5924:7755e] [com.teamviewer.Helper:-P0-3] Client is located in /Applications.
    2021-12-15 14:27:10.481 Df com.teamviewer.Helper[5924:7755e] [com.teamviewer.Helper:-P0-3] Static client validation passed.
    2021-12-15 14:27:10.496 Df com.teamviewer.Helper[5924:7755e] [com.teamviewer.Helper:-P0-3] Connection invalidated, exiting.
    2021-12-15 14:42:43.800 Df com.teamviewer.Helper[6762:7e1a6] [com.teamviewer.Helper:-P0-3] Dynamic client validation passed.
    2021-12-15 14:48:14.681 Df com.teamviewer.Helper[6762:7e1a6] [com.teamviewer.Helper:-P0-3] Client is located in /Applications.
    2021-12-15 14:48:14.681 Df com.teamviewer.Helper[6762:7e1a6] [com.teamviewer.Helper:-P0-3] Static client validation passed.
    2021-12-15 14:48:14.776 Df com.teamviewer.Helper[6762:7e1a6] [com.teamviewer.Helper:-P0-3] Connection invalidated, exiting.
    2021-12-16 07:06:25.236 Df com.teamviewer.Helper[783:3740] [com.teamviewer.Helper:-P0-3] Dynamic client validation passed.
    2021-12-16 07:19:29.333 Df com.teamviewer.Helper[783:3740] [com.teamviewer.Helper:-P0-3] Client is located in /Applications.
    2021-12-16 07:19:29.333 Df com.teamviewer.Helper[783:3740] [com.teamviewer.Helper:-P0-3] Static client validation passed.
    2021-12-16 07:19:29.379 Df com.teamviewer.Helper[783:713d] [com.teamviewer.Helper:-P0-3] Connection invalidated, exiting.
    2021-12-16 07:44:20.231 Df com.teamviewer.Helper[1676:112e0] [com.teamviewer.Helper:-P0-3] Dynamic client validation passed.
    2021-12-16 07:45:04.029 Df com.teamviewer.Helper[1676:112e0] [com.teamviewer.Helper:-P0-3] Client is located in /Applications.
    2021-12-16 07:45:04.029 Df com.teamviewer.Helper[1676:112e0] [com.teamviewer.Helper:-P0-3] Static client validation passed.
    2021-12-16 07:45:04.084 Df com.teamviewer.Helper[1676:112e0] [com.teamviewer.Helper:-P0-3] Connection invalidated, exiting.
    maxsmac@Maxs-iMac ~ %
    Hello MoreCoffee,
    I will type in the second command and send these over to you shortly.
    Kind regards,
    Max
    Hello MoreCoffee,
    I look forward to hearing from you very soon,
    Max
    @Max_L2z That actually doesn't look too bad. Do you also have output for the first command (the one with "log show")?
    Hello MoreCoffee,
    Here are the results from the second command:
    1.52s real 0.99s user 0.45s sys
    Kind regards,
    Max
    Hello MoreCoffee,
    Please find the results from the second command:
    I look forward to hearing from you,
    Kind regards,
    Max
    Something very strange.
    Be carefull I think MOD or TV Staff will answer your question soon.
    mLipok , AutoIt MVP
    Hello MoreCoffee,
    Thank you for getting back to me today.
    I haven't used this 'coding' ever on an iMac before - where do I start? Do I start in System Preferences? Could you please help and take me through it step by step?
    I have to work from the office because of this issue during these uncertain covid times and the sooner I work from home, the safer I'll feel.
    Kind regards,
    Max
    Hello MoreCoffee,
    It will operate normally when you cancel the password prompt twice, but then the next day when I restart, the same window pops up asking for the same thing?
    I do need to sort this out as I need to work from home due to the virus.
    Kind regards,
    Max
    @Max_L2z Does TeamViewer seem to operate normally if you cancel the password prompt (twice)?
    Hello MoreCoffee,
    I have tried what you have suggested (downloading the most up-to-date version etc.), then I've restarted and the same 'Helper Tool' window has popped up again? What else can I try as this issue is preventing me working remotely.
    Kind regards,
    Max
    Thanks. I will certainly give that a try.
    User: "Yuri_T"
    [Former Staff]
    Hi @RJG1999
    Thank you for your post😊
    We are checking the issue internally. I will keep you updated if there is any more information I get.
    Kind regards,
    Yuri
