"Disable Remote input" doesn't disable touch screen input
HansO
Posts: 12 ✭✭
Hello
When I click "Disable Remote Input" the remote keyboard and mouse is disabled.
However the touch screen input isn't disabled? (ie the user can still use the touch the screen to click button and move windows)
The remote computer is running Windows 10 btw
I also have the same problem with the same operating system, is it possible to know if there is a solution?
I've been in touch with TeamViewer support.
It's a known issue with no known solution or expected timeline for a solution.
1
