SHIFT and CTRL not working for Teamviewer + Remote Desktop
SHIFT and CTRL are working for my teamviwer session to the remote computer with Windows 10. Also when directly logged in to the remote computer a Remote Desktop to another system with Window 7 works fine. For the combination of Teamviewer + Remote desktop however, the SHIFT and CTRL key are not working. Does anybody know why?
Hi though i was going mad, same issue hear, Teamviewer into Windows 10 comptuer, Shift Keys and CAPS and CTRL all work fine.
Once connecting into RDP Windows 7 PC, with in Teamviewer session, the trouble begins, can't type with Shift key, Ctrl + combinations don't work and sam with CAPS . ??
Surely someone has found a fix to parse the keyboard info through to RDP with teamviewer?
2 -
Same problem here, but all three computers are Windows 10
I solved this by not using full-screen for the RDP session.
Hello @DeHaan58
Thanks a lot for sharing this workaround. ??
@BertK and @darwall, can you confirm that this workaround fixes the issue on your side as well?
Best regards
Unfortunately the workaround doesn't work for me. Using Notepad on the 2nd computer in a non-fullscreen window, selecting text and typing ctrl-C just replaces the selected text with a C. Instead of copying it to the clipboard.
I'm sorry to hear that. You say '2nd computer' (first is the TeamViewer client, second is the TeamViewer host, third is the computer controlled by RDP) When at the second computer I start mstsc.exe and I choose Full-screen I have the problem. When I start mstsc.exe and I choose for example 1440 x 900 I don't have the problem.
I also created a TeamViewer support ticket because I use Full-screen most of the time. No response yet.
Excuse me, in your terminology I should say "3rd computer". But anyhow, I can't reproduce your workaround. For me the problem occurs in a full-screen RDP as well as in a windowed RDP session.
This has been bugging me for a long time now. I've actually switched to another solution because of this.
I figured I'd see if this has been resolved yet, but it isn't. Any updates from Teamviewer? Acknowledgement that it is in fact a known issue? Is there any bug report?
I have had this issue for years. Full Screen mode sometimes works but most times it does nothing. Makes things like typing in a password with capitols very difficult.
Same problem here. More than a year after initial bug report.
Any update from Teamviewer team when this will be solved?
I also have the same problem, very annoying!
I had the same problem, but only when I use the option "Show empty screen". When I turned this off, I didn't had the problem, but of course this is less secure.
Reading some information about this item at the community-site of Microsoft, I found out that you can change the keyboard-settings at the options of the RDP-client. Setting "Apply Windows key combinations" to "On this computer" solfed the problem for me.
This is the last time I'm renewing Teamviewer in any of the organizations we support if this issue isn't addressed. This is so fundamental to have keystrokes passed to the remote client that TV should stop developing any other bells and whistles to solve this.
It's not just RDP it can be other applications that are affected too. vSphere remote console is also affected.
N.
Same to me
For me, it is only when "Disable remote input" is enabled in the initial Teamviewer connection, regardless of full-screen or not in RDP.
Where can I find the suport ticket?
I'd like to "support" it if possible! :)
