Hi there, We are trying to use the Patch Management but there is a lot of little issues. My Question is about the Software Catalog. Checking on TeamViewer website the Software Catalog is over 1 year old. Does this mean the Catalog was NOT update for 1 year? https://static.teamviewer.com/resources/2021/04/Software-Catalog.pdf
Off topic but - there seems to be plans for custom software deployment. Not sure if you are able to comment on that, but I do see it when poking around in the software deployment section of TV.
Hello @itsouth
I checked on the main page for TeamViewer Patch Management, and the active link there is from last October:
Here is a direct link
Could you please let us know where the older pdf you found was linked from?
Thanks in advance!
