Easy solution for monitoring 9+ clients simultaneously
pf_gh
pf_gh Posts: 1
edited April 2022 in General questions
Hi all — I'm running TeamViewer on multiple end-points (Linux/RaspberryPi) and want to be able to see real-time (or near real-time) views of all the clients that I've setup as managed devices, on a grid view.
Is there an official / concise way to get multiple (9+) TeamViewer remote clients to be visible in a grid-style dashboard view?
Thanks all
  • Ying_Q
    Ying_Q Posts: 2,605 Moderator
    Hi @pf_gh,
    Thank you for posting in TeamViewer Community!
    Currently TeamViewer only has the option of Open new connections in tabs. You may find the option on TeamViewer client GearWheel⚙ (top right corner) -> Remote control -> Remote control defaults -> open new connections in tabs -> tick.
    If this option is not ideal for you, you may leave it untick. Then manually adjust all the connection windows into the preferred window size to fit your screen.
    We are sorry for the inconvenience and feel free to comment below if you would like to know more other features about TeamViewer!
    Have a great day!
    Community Moderator/中文社区管理员
