Hello, is it possible not show the ID for my user that only can connect in another teamviewer? What I need is to find a way that the person that is going to connect doesn't have an ID, so no one can connect in that machine... is that possible?
Hiding the ID:
I don't know a way to make the ID show up as a dash (- - - ), but there are some alternatives.
Options > General Tab > Check Use new user interface (preview)
Hiding (or showing) your temporary password:
The password is displayed as blank or dashes if there is no temporary password. Options for temporary passwords are in:
Options > Security Tab > Password strength
No password means it is set to disabled.
If I want to connect and help people, but I don't want anyone to connect to me...
Options > Advanced > Access Control = Deny incoming remote control sessions
Deny Incoming Connections
I hope that helps.
When user execute TeamViewer app, it shown ID and Password. We don't want nobody to see it. How do I prevent users to see Your ID and Password when they launch TeamViewer 14 (assume I write down the PC's TeamViewer ID and password of that device)
It is actually the password I believe he is talking about. My password comes up like a dash, just like his picture. How do I get a password to come up? It used to bring one up automatically.
Thanks!
Actually I'm talking about this ID (in my own machine). Is not possible live a " -" like the password?
If you are talking about the message that shows current connections, I don't think that can be hidden. The message can be minimized, but your ID will still be there. Your ID will also show up in the local log files.
Incoming ID
This is perfect. That helps a lot!! Thank you for this !!
Besides that is it possible not to show the ID, or is it not possible?
