getting desktop notifications when a contact goes online
For a few of my "computers and contacts", I keep getting desktop notifications when they go online (even when TeamViewer is idle), and that's annoying sometimes.
How can I disable these notifications?
Hi @glu,
Welcome to the Community and thank you for reaching out to us✨
I totally understand how you feel about the notification. But do not worry, there is a setting for that😉
My colleague @Justin already mentioned how to disable the notification below. Could you please check the process on the GIF and try if this helps you?
It would be really great if you could tell us how this goes.
Have a good day🌞
Akiho
Japanese Community Moderator / コミュニティモデレーター
1
Hi @glu,
Have a good day🌞
Akiho
Thanks Akiho.
The process in the gif indeed helped solve my issue.
However, it would have been easier for me if the answer included only that gif: since my question was very specific, it confused me a bit to look at all the possibilities in that answer.
thanks again
Hi @glu
Thank you for getting back to me☺️✨✨
Great to know that it solved your case!
But I'm sorry to hear that my guide confused you.
I'm really grateful that you come back with the feedback. I take your feedback seriously and provide a more straightforward /clear guide to you next time.
Hope to see you again in the Community🍀
Warm regards,
Akiho
