Good morning,
we have a generall problem that the installation of an personal TeamViewer Host is not registering the Clients into the desginated computergroup.
We have checked the API-Token, the group id and the config id on the installation process.
Also we have installed the msi and put the command to manually put the client in the right group.
This only worked with the full client installation but NOT for the personal client installation.
We can use TeamViewer but cannot access the client with easy access.
Maybe someone had the same problem?
Iam greatful for every help.
Greetings from Germany :)
