[Linux] v15.31.5
JeanK
edited July 2022 in TeamViewer Remote
Operating system: Linux
Version: 15.31.5
Release date: 2022-06-28
New features
  • The remote cursor is now also transmitted during a connection if Wayland is used on the remote side. Note: Wayland support is still experimental.
  • Matt_Gulick
    Matt_Gulick Posts: 1
    The recent update prevents me from connecting to my remote system (free, personal use).
    When I select "Connect", it brings up a password dialog - same as prior system.
    The issue is that the dialog closes before I can enter my password. I then get a message saying I must wait * seconds because of too many failed attempts.
    Details:
    • OS: Ubuntu 18.04.6 LTS
    • VPN: Cisco Anyconnect Secure Mobility Client
    • Memory: 31.3 GiB
    • Processor: Intel® Core™ i7-9700 CPU @ 3.00GHz × 8
    • Graphics: Intel® UHD Graphics 630 (CFL GT2)
    • GNOME: 3.28.2
    • OS Type: 64-bit
    • Disk: 485.8 GB
    • TeamViewer Version: 15.31.5
    • Date: June 23 2022 11:56:50
    • License: Free
    teamviewerd.service:
    [Unit]
    Description = TeamViewer remote control daemon
    After = network.target network-online.target dbus.service
    Wants = network-online.target
    Requires = dbus.service
    [Service]
    Type = forking
    PIDFile = /var/run/teamviewerd.pid
    ExecStart = /opt/teamviewer/tv_bin/teamviewerd -d
    Restart = on-abort
    StartLimitInterval = 60
    StartLimitBurst = 10
    [Install]
    WantedBy = multi-user.target
    teamviewer.list
    ###  TeamViewer DEB repository list
    ### NOTE: Manual changes to this file
    ###       - prevent it from being updated by TeamViewer package updates
    ###       - will be lost after using the 'teamviewer repo' command
    ###      The original file can be restored with this command:
    ###      cp /opt/teamviewer/tv_bin/script/teamviewer.list /etc/apt/sources.list.d/teamviewer.list
    ###      which has the same effect as 'teamviewer repo default'
    ### NOTE: It is preferred to use the following commands to edit this file:
    ###      teamviewer repo               - show current repository configuration
    ###      teamviewer repo default       - restore default configuration
    ###      teamviewer repo disable       - disable the repository
    ###      teamviewer repo stable        - make all regular TeamViewer packages available (default)
    ###      teamviewer repo preview       - additionally, make feature preview packages available
    ###      teamviewer repo development   - additionally, make the latest development packages available
    deb https://linux.teamviewer.com/deb stable main
    # deb https://linux.teamviewer.com/deb preview main
    # deb https://linux.teamviewer.com/deb development main
    Other files available on request.
    Matt Gulick
  • keirak
    keirak Posts: 1
    edited July 2022
    @JeanK I am unable to log into the Teamviewer application. The app launches and I click on the "Sign-in" Tab but all of the fields are grayed out and I can't fill them out, thus allowing the app to log in. Apparently, this wasn't properly tested. Please provide link to a previous version so that I can get up and running again.
    edited July 2022
    Hello @Matt_Gulick and @keirak,
    Thank you for your messages and welcome to the TeamViewer Community!
    Before going into a deeper investigation, could you please try to reinstall TeamViewer on your devices and check if it solves the issues?
    Many thanks in advance.
    /JeanK
