Ubuntu - Window after connection never actually appears
Sure4Thing
Sure4Thing Posts: 3 ✭✭
edited July 2022 in Linux only
So when I connect to ANY partner computer from teamviewer, it will prompt for password and then the window disappears. I have tried newer versions, uninstalling and reinstalling, and then an older 15.X version and it is still the same behavior.
I dont have this issue on my Windows computer. Any suggestions? See the attached video for exact issue.
  • Sure4Thing
    edited July 2022
    My video seemed to have been removed due to Community Guidelines???? Please take a look at the video because I dont know exactly how to describe this behavior.
    [removed per Community Guidelines - please do not display TeamViewer IDs]
  • Sure4Thing
    I fixed my issue after my video was removed again.
    Basically, the window manager was causing it to start super small. I tried a bunch of complicated fixes but ended up just using the Windows key and an arrow to cause it to snap which restored the window.
