QuickSupport app on iPad - can't see remote screen
CW2022
CW2022 Posts: 3 ✭✭
Hi, I installed the QuickSupport app on my mother's iPad. She's 91 and struggles with the tech sometimes.
It's been working fine.
But today we've tried several times to start a session.
At my end it says the connection has been established, and at her end the broadcast has started.
She can see the red button flashing. But I can't actually see her screen.
Why is this?
Is there a button I need to press in order to show the screen?
Thanks.
    Answer ✓
    Hello @CW2022,
    Great to see you posting for the first time!
    Once you enter the iPad's ID, the remote user needs to:
    1. Accept the connection by clicking Allow
    2. Click on Start Broadcast
    3. Confirm the Screenbroadcast by clicking Start Broadcast again
    Let me know if this could help!
    /JeanK
    Answer ✓
    Hello @CW2022,
    /JeanK
  • CW2022
    CW2022 Posts: 3 ✭✭
    Thank you for your quick reply! I'll try again with my mother. She was already doing what you suggested but for some reason I couldn't see her screen at this end, although the app (on my MacBook Pro) said that the connection had been established.
    Someone from Apple is helping her with the iPad now. If that problem is fixed, maybe it will fix the QuickSupport issue as well.
    I'll let you know.
    Thank you for the update. Looking forward to hearing from you!
    /JeanK
  • CW2022
    CW2022 Posts: 3 ✭✭
    Hi Jean, I was able to visit my mother at the weekend and do a test with her iPad and my laptop side by side. It's working now. It may be that it was the issue with her Apple user ID that had stopped the iPad from working properly. Thanks for your help.
    Hi @CW2022,
    Thanks a lot for sharing your update.
    I'm glad it's sorted and that you can now assist your mother via TeamViewer! ✨
    I hope to see you around soon.
    /JeanK
