Hi, TeamViwer
When I Try to connect from pc to mobile, the TVQS crashes. TVHost app is same. Please refer below.
Thanks.
Hi @Kiwoo,
Welcome to our Community! 🤩
First, could you please check out if the mobile device is supported for remote control: 👉 Supported manufacturers for remotely controlling Android devices
Second, when installing the TeamViewer app on the device, if it is required, make sure to install as well the add-on. You can find more information in our FAQ: Remote control for Android
Let us know if you need further assistance,
Jen
