teamviewer freezes my iphone when I try to connect to my desktop
Teamviewer works fine when I try to connect to my laptop with my iphone. It also works fine when I try to connect to my desktop with my laptop. I have already tried reinstalling teamviewer. I have also tried removing the desktop from list of my computers and reinstalling it.
    JeanK Posts: 6,444 Community Manager 🌍
    Hello @princealbert16,
    Thank you for your message. ?
    Have you checked if the OS version of your iPhone is compatible with TeamViewer?
    You can check this here: Supported operating systems - iOS and iPadOS
    I hope this could help. ?
    Best regards
  • Kehowell
    Kehowell Posts: 1 Newbie
    I recently am experiencing the same challenge. I have the biometric settings in the app enabled and it seems to freeze the phone when trying to use the camera for authenticating. The challenge is that I cannot get into the application to remove that option. This just started occurring within the last month as I accessed with no issues about 3-4 weeks ago.
