I am trying to use Teamviewer Host but all it allows me to do is connect to the device, I am unable to remote control to the device
Hi there,
Thank you for your reply @Kurtmin and for jumping in @Salenley 🙂
Do you have the same issue if you connect to another remote device from the same local machine?
I would also need to know: when you connect to the remote device, do you arrive on the lock screen, or is the Windows user session already open?
💡 Little tip: if it is possible for you, you can check if the keyboard answer. Indeed, if you can tap something but the mouse itself is not responding and the material is Bluetooth on the remote side, you can try to:
After that, please try to connect and control the remote machine.
I hope that you'll be able to control the device with those advices,
Jen
The same issue happen with me What Should we do any video Tutorial, any document that would be helpful....
Already tried all of that, we used to use Quicksupport in the past but that needed user intervention which was not practical, host gives us the option for remote control with no user intervention which is why I am trying to use it
Hi @Kurtmin,
Thank you for your post! 🙌
You will need to check different options, according to the device.
1️⃣ First, on your local device: please check the settings Advanced settings for connections to other computers and select Full Access as below:
2️⃣ If the issue remains, on the remote device: please check the settings Advanced settings for connections to this computer and select Full Access. To access the Host options, click on the gear icon ⚙️ as shown below:
If the Access Control settings are both on Full Access and you still can't control the remote device, please let us know to investigate further 😊
Have you heard?! On October 21, we’re hosting TeamViewer Rise—and we want to see you there! The digital event dedicated to IT experts. Join us to hear industry leaders as they share demos, roadmaps, and real-world strategies for delivering better IT. Take part in our first annual event for Proven, ready-to-deploy…
