what is happening with drag and drop?
I'm unable to use my mac properly
When I try to drag and drop items, they just get sticky to the mouse cursor.
Any idea what is happening or how to solve it?
  • elstie
    elstie Posts: 2 ✭✭
    I'm having this exact issue. Been happening over the last month or so. I'm remote controlling a Mac from a Windows PC.
  • joaoserraseal
    joaoserraseal Posts: 4 ✭✭
    edited April 2022
    My suggestion is... quit using team viewer, seems no1 cares so...
    I've looked and looked on the web, all I found was generic solutions for something that looks like a really old bug from macOS which I don't think is the same cause all they talk about is dragging files and for me it happens everywhere... solutions like...
    restart your mac or restart finder or check mouse batteries or buy a new mouse... **Bleep**..😑🔫
    I'm using **Third Party Product** and up until now I didn't had any issue
  • LU7
    LU7 Posts: 1
    Unfortunately I'm having the same issue. It's really fustrating because TeamViewer works great but if this isn't resolved soon then I'll be forced to look into another remote access solution.
  • joaoserraseal
    looks like i was censored
