How to set mouse pointer size?
I know I can change the color of the mouse pointer but how can I change the size?
I have changed the size on the pc I am viewing but it is too small on the viewer PC
Thanks for any advice
Bob
    Hello @BobbyTee
    The mouse pointer is a fixed standardized item.
    Unfortunately, there is no possibility to modify the size of it.
    Best regards
  • dany
    dany Posts: 1
    Is there any improvement on this topic ?
    I have big difficulties to see the remote computer pointer .
  • Donhembree
    Donhembree Posts: 1
    Teamviewer is almost unusable due to the small size of mouse pointer. I just read that this is not adjustable. Unfortunately i'm going to have to cancel my Teamviewer membership and go with another remote access service.
  • DarkLordNin
    DarkLordNin Posts: 1
    This needs to be sorted. Very difficult to use otherwise. Making me look for alternative products.
  • jconnor
    jconnor Posts: 1
    Turning on the mouse pointer trails isn't a perfect solution, but it helps.
