Multiple Monitors Disconnects Session
Hello, Community!
I've recently downloaded and installed the latest version of Teamviewer to two of my machines, one virtual machine, one Lenovo ThinkPad T560. I connect from my T560 over to my virtual machine just fine. However, once I click the second monitor and try to use it, my session disconnects.
It's not every time, but it seems to coincide quite a bit. I use the free license of Teamviewer and have both of them in my account for quick and easy access. Is opening a second monitor and using both as fullscreen a paid subscription feature, or should this not be happening?
If I only use one monitor, then everything is great.
    Hello @A_User,
    Thank you for your message and welcome to the TeamViewer Community! 🙌
    Using multiple monitors is not restricted to the free license. So it should be working fine.
    It sounds more like a connection crash. Have you tried reinstalling TeamViewer on the impacted devices and checking if it works better?
    Looking forward to your reply.
    /JeanK
