Devices API endpoint question
AndrewTaylor
AndrewTaylor Posts: 2 ✭✭
edited October 2022 in Deployment & Integrations
I want to use the Teamviewer API to automatically remove our machines from Teamviewer, i can see there is the devices endpoint /api/v1/devices with the parameter option for "name" that will return the device ID
However when I use that endpoint with a device name (https://webapi.teamviewer.com/api/v1/devices?parameters.name=DV00310) it just returns a full list of every machine in our organisation. I can see on the returned json that "name" isn't actually an option it returns, am I using this wrong?
"devices": [
"remotecontrol_id": "string",
"device_id": "string",
"userid": "string",
"alias": "string",
"groupid": "string",
"description": "string",
"online_state": 0,
"policy_id": "string",
"assigned_to": true,
"supported_features": "string",
"last_seen": "2022-10-18T10:07:33.519Z",
"teamviewer_id": "string"
Can someone point me in the right direction? My aim is to create a script that allows us to delete a device based on its hostname, I know you need the device ID to call the endpoint which is why I'm wanting to filter out the info based on the device name
Thank you,
Andrew
  • SuperD0S
    SuperD0S Posts: 13 ✭✭
    did just this a couple of days ago, since there's no way to fetch a single device you need to get all devices and the filter out the right computer via Alias. After that use the DELETE /api/v1/devices/{id}
  • AndrewTaylor
    @SuperD0S Thats what i was hoping to avoid, had a similar attempt go wrong a few years ago, do you have a sample script I could reference by any chance? I'll be writing this in Powershell but any language would be good to see
  • SuperD0S
    Forgot to say you can query a single device but you need to use the Teamviewer ID but often you want to query via the alias field which often is the computer name.
    Here's a script that utilize a script token that you can create in TeamViewer Mangement Console (https://login.teamviewer.com/nav/profile/apps):
    #Remove Teamviewer Device
    #Vars
    $tvApiVersion = 'v1'
    $tvApiBaseUrl = 'https://webapi.teamviewer.com'
    $accessToken = 'ENTER YOUR SCRIPT TOKEN'
    $DeviceApi = "$tvApiBaseUrl/api/$tvApiVersion/devices"
    function Get-TeamViewerDevices {
      param (
        [Parameter(Mandatory = $true)][string]$accessToken,
        [Parameter(Mandatory = $false)][string]$deviceID,
        [Parameter(Mandatory = $false)][string]$alias
      try {
        if ($deviceid -and !$alias) {
          $(Invoke-RestMethod -Uri "$DeviceApi/$deviceid" -Method Get -Headers @{authorization = "Bearer $accessToken" } -ErrorAction Stop).devices
        elseif ($alias -and !$deviceid) {
          $(Invoke-RestMethod -Uri $DeviceApi -Method Get -Headers @{authorization = "Bearer $accessToken" } -ErrorAction Stop).devices | Where-Object -FilterScript { $_.alias -match $alias }
        elseif (!$alias -and $deviceid) {
        else {
          "Please Use only deviceID OR alias!"
      catch {
        Write-Error $PSItem.Exception.Message
    function Remove-TeamViewerDevice {
      [CmdletBinding(SupportsShouldProcess)]
      param (
        [Parameter(Mandatory = $true)][string]$deviceid
      try {
        if ($PSCmdlet.ShouldProcess($deviceid)) {
          Write-Host "Deleting TeamViwer device: $deviceid" -ForegroundColor Green
          $(Invoke-RestMethod -Uri "$DeviceApi/$deviceid" -Method Delete -Headers @{authorization = "Bearer $accessToken" } -ErrorAction stop )
        else {
          Write-Host "WhatIf: The TeamViewer device with ID $deviceid will be deleted!" -ForegroundColor Yellow
      catch {
    #Example: Remove Computer with Alias "TestComputer"
    $device=(get-teamViewerDevices -accessToken $accessToken -alias "TestComputer").device_id
    Remove-TeamViewerDevice -accessToken $accessToken -deviceid $device
  • SuperD0S
    @AndrewTaylor did you get it to work?
