Two Monitors
oregon_george
Posts: 6 ✭✭
My desktop has two monitors.
On my Android, TeamViewer allows me to choose Mon 1 and Mon 2 separately. That works fine.
How can I view both monitors are the same time? What I want is Mon 2 to be displayed just to the right of Mon 1 on the Android.
The monitor select option on the Android should say or toggle as follows:
Mon 1
Mon
Both
and back to Mon 1 again.
George
You cannot, basically because there is not enough space on a typical Android display. And it doesn't work on Windows either (i.e. I'm connecting from one laptop to another with 2 screens attached to it, I can only see one display at a time).
Thank you for your reply. I appreciate it.
