[Windows] v15.39.3
Natascha
Operating system: Windows
Version: 15.39.3
Release date: 2023-02-21
Improvements
  • Added the ability to join a session from the Windows client using a session code.
  • Billrjoh
    Billrjoh Posts: 4 ✭✭
    Upgraded to version 15.39.3. Then a window popped up to start migration (new). Migration to what??? No explanation about migrating to what and why? Its never done this before.
  • .Carol.fg.
    .Carol.fg. Posts: 1,083 Moderator
    Hello @Billrjoh ,
    Thanks for your question and welcome to our Community!
    This message is about our Managed Devices feature.
    You can read more about it in our article: 📄 Managed Devices - General information
    The step by step for the update you can find here: 📄 Update your devices
    Let us know if you have any further questions.
    Best Carol 👩🏻‍🦰🌷
  • Aditza
    Aditza Posts: 16 ✭✭
    edited February 2023
    the problem with the mandatory SYSTEM account service that's being forced to run at all times is still present in this version.
    Even if i set TeamViewer to not start with Windows and i disabled on purpose the NT Service, after the upgrade i find the service was forced enabled in the background again, without consent.
    before update: (TeamViewer service is disabled and not running)
    after update... the system service is forcefully enabled and started in the background:
  • JimmyZ
    JimmyZ Posts: 13 ✭✭
    I have 2 computers in my home. If they are both turned off the android app will NOT wake eather of them, and they will remain off. If one of the PC's is on, the android app will wake the second PC. This started to happen with the Feb update. I rolled back to the previous version and it worked again, then the app on my phone updated and the issue came back again.
    What can I do to fix this? One PC is W10 Home, the second is W11 Pro.
