Microphone Transmission
I know that I can hear the sound of host pc on Client side.
But I also want to know I can transmitt my voice from client pc to the host pc.
Thanks,
Irina
    Hello @irinababina211,
    To transmit your voice to the Host PC, you need to start an internet call.
    All you need to do is to go to Communicate and click on Start Internet Call:
    I hope this could help. ?
    Best regards
  • irinababina211
    irinababina211 Posts: 2 ✭✭
    edited March 2023
    Thanks for your reply. I tried to follow what you mentioned but it didn't work out. I am attaching the screenshot below to show what I want exactly.
    I started the internet call and performed the online mic tests on both, host and client pcs at the same time.
    When I made a sound, the graph on the client pc represented it, but no changes on the host side as the screenshot shows.
    Having the same result on both graphs is what I want.
    If you have any more suggestions, please share it with me.
    Thanks,
    Irina
  • MaracchiA
    i want to start a skype conversation on the REMOTE computer from my home computer.This because the company skype for business in enabled on my work PC only.
    I want to use the microphone connected to my home computer to make calls from the remote computer. NOT a teamviewer audio conference.
    It seems this is impossible.
  • BernardoMB
    BernardoMB Posts: 2 ✭✭
    Any update on this?
