Ok heres the problem. When I log on to my partner, everything is fine. When I disconnect from my partner and try to log on again, it allows me to do so. However, in about 1 - 2 mins, I’m auto disconnected and I can no longer connect to my partner.
It gives the same message when I try to connect, “partner offline…” I believe the teamviewer app had been shut down on my partner device. The only way I can connect again is to re open the teamviewer on my partner. But the same problem described in para 1 persists. I’d greatly appreciate any help, please.
