Session is from Ubuntu 20.04
System
System Posts: 464 ✭✭
This discussion was created from comments split from: [Linux] v15.40.8.
  • lepingouin
    lepingouin Posts: 6 ✭✭
    Each time TeamViewer hangs when disconnecting, a bzip2 process run at 100 % for 30 s before quitting.
    Session is from Ubuntu 20.04 to Windows 10, hope it helps.
    Gerard
  • lepingouin
    Problem is related to Cinnamon desktop, there is no issue with Gnome Desktop.
    I don't know for others...
  • lepingouin
    After a reboot, issue came back even with Gnome Desktop.
    It seems related to the pop-up window showing up after disconnecting from the session if you are not using commercial release.
  • lepingouin
    Extract from dmesg command after bzip2 process quit:
  • Jaaxx
    Jaaxx Posts: 1
    Can confirm this behavior on Mint 21 with XFCE desktop.
  • shtTeJ
    shtTeJ Posts: 1
    edited August 2023
    can confirm on Arch Linux (Kernel 6.4.8-zen1-1-zen) with i3wm as desktop. Using dunst as notification (pop-up) daemon ( https://github.com/dunst-project/dunst/).
  • crimsonfez
    crimsonfez Posts: 1
    Fedora 38 and Gnome also has this behaviour. Maybe it's archiving logs... or stealing user data, who knows.
  • IroNiQ
    IroNiQ Posts: 1
    Just look into $HOME/.local/share/teamviewer15/logfiles directory. I could find there bzip2-compressed core files even when my core size is set to 0.
