Codecs for TeamViewer convertion
Hyall!
Win8.1x64
I have only these codecs trying to convert .tvs files
K-Lite codecs pack & distinct ffdshow codec had been installed
How to add new codecs to TeamViewer converter?
BTW msinfo32 also shows only 'standard' win codecs
  • Esther
    Esther Posts: 3,627 Community Manager 🌍
    Hi @abikarus
    Does this article maybe help you? How to convert a recorded TeamViewer session
    All the best, Esther
  • Hi!
    As I said, I had installed ffdshow codec. And K-Lite codecs package as well
    But in TeamViewer's menu they are abscent!
  • So, is it possible to add new codecs into TeamViewer built-in converter?
  • Scotty
    Hi abikarus,
    Unfortunately no, it is not possible to add additional codecs into the TeamViewer converter. It can only convert to the codecs listed.
    Sorry about that.
    -Scotty
    Senior Moderator
  • It is possible to add additional codecs into TeamViewer for conversion.
    Click the link provided above by the TeamViewer Community Manager to the knowledge base article, and scroll down to the "Minimum File Size" section at the bottom.  Here is the link again.
    Unfortunately, I don't know how to do it though - that is how I ended up here.  I have ffdshow installed, but it doesn't show up in the converter Codec drop-down list.  Check out this video of a guy who uses ffdshow, but doesn't explain how to make TeamViewer see the codec.
  • pu5her
    pu5her Posts: 1
    You need to install 32-bit version of ffdshow
  • newuser
    newuser Posts: 1
    I found this googling the exact same problem, and now that I found a (quite simple) way to get more codecs to show up and I want to share that for the next guy/gal:
    I have TeamViewer 9 on Windows 10 and even with installing K-Lite and ffdshow, as was mentioned here too, I could only extend the liste to a rather unusable ffdshow option (very large file size and quality issues).
    I uninstalled both TeamViewer 9 and the K-Lite Codec Pack and then FIRST re-installed the Mega K-Lite Codec Pack (don't know if it's necessary to use the complete version) and only afterwards I re-installed TeamViewer. (To be safe I rebooted the system after each step because, you know, Windows).
    With that order, TeamViewer apparently is able to recognize the installed codecs completely and other codecs finally showed up in the conversion options:
    lw9OtWK
    So it is possible, I hope this helps although I have a very old version of TeamViewer. If the issue persists in newer versions, it should be possible there too.
