RevPi IoT - Remote control shows black screen.
I have install the teamviewer iot agent and connected a revpi with mit teamviewer IoT account which worked fine.
The I tried to configure the remote control following this instructions for the X11-Server
But every time I connect I can only see a blank black screen.
So what can I do to solve this?
[teamviewer-iot-agent: version 2.22.2]
I have the same problem. I am trying to access and control my RevPi (based on Raspberry Pi) from my computer. I am able to see the terminal and app but the screen shows blank black screen.
Followed all the instructions from in here:
Set up the remote screen via X11 - TeamViewer Support
Is there a possibility that **bleep** causes conflicts? And teamviewer access is not available.
Meanwhile if i add the exact screen inside global.conf
X11:0:pi then i get this problem: It is not possible to capture the screen of the remote device. Please check your setup and try again.
Lastly using the remote terminal through teamviewer i the command xdpyinfo command i get this error (not received when working directly inside Raspberry):
If i edit FileTransferAccessControl to 0 to allow full control, Teamviewer never connects.
