When connecting from 1 Window 11 PC, when clicking on Start, the menu is not shown, only the bottom bar, with your name and the Power button.
With one of the last updates, this issue went away. Thanx.
It might be possible that the wrong resolution is set during your connections.
You could try to change the resolution and check if it fixes the issue.
You can access the Screen resolution from the View menu within the remote session toolbar.
Please find more information about this topic here.
/JeanK
With the latest couple of software updates, I am now seeing the Start Menu icons.
Same here. scrolling up and down in secondary windows doesn't work.
MAC connected to Win11.
Sorry, still having the issue.
I'm seeing the same issue as jazzybob. Have you figured it out?
I'm experiencing the same thing. I get a black vertical bar, that's it. I can't scroll through any OS windows, I can't scroll through Outlook 2019 emails. The elevator bar goes up and down, but the screen does not change. All browsers appear to be functioning properly.
Edition Windows 11 Pro
Version 21H2
Installed on 7/30/2021
OS build 22000.434
Experience Windows Feature Experience Pack 1000.22000.434.0
