Feb Update and android not working...
JimmyZ
JimmyZ Posts: 13 ✭✭
edited March 2023 in General questions
I have 2 computers in my home. If they are both turned off the android app will NOT wake eather of them, and they will remain off. If one of the PC's is on, the android app will wake the second PC. This started to happen with the Feb update. I rolled back to the previous version and it worked again, then the app on my phone updated and the issue came back again.
What can I do to fix this? One PC is W10 Home, the second is W11 Pro.
The log file says that the PC's Wake up was not set up.
  • JimmyZ
    JimmyZ Posts: 13 ✭✭
    Answer ✓
    BOY this Community is Great. So much help and support. Still have the issue, but with differant entries in the log file. see my other 'NEW' post. for more info.
  • JimmyZ
    JimmyZ Posts: 13 ✭✭
    Answer ✓
