Multi thread .NET application not responding after using TeamViewer
I am using teamviewer to connect to a remote machine with Windows 7 enbeded. This works fine, bus sometimes after closing the teamviewer connection, the .NET application on this machine doesn't respond anymore. The rest of the computer is still working fine, only this .NET application not. This is a multi-thread application. All the background threads of this application are still working, only the display doesn't respond on any key.
  • Ying_Q
    Ying_Q Posts: 2,621 Moderator
    Hi @Erik_roboflex,
    Thank you for visiting the TeamViewer Community!
    We would like to update you that TeamViewer is not compatible with Windows 7 embedded. Can you kindly try to update the operating system and then try again with TeamViewer please? For more information on TeamViewer compatibility, we have prepared the knowledge article -Supported operating systems for TeamViewer (Classic). Hope it helps to guide you with the right compatibility.
    Community Moderator/中文社区管理员
  • Erik_roboflex
    Erik_roboflex Posts: 2 ✭✭
    Hi @Ying_Q,
    Unfortunally I can't update the operating system. Is there an other way to let it work? perhaps a previous version of TeamViewer?
