Android BOX Teamviewer Host
DLyons_REDEPOS
Posts: 2 ✭✭
Hello
I have bought a couple of different Android boxes to be used with Teamviewer host but teamviewer doesnt work on the T95Z using Anroid 12 it just permanently loads and I have tried resetting to Factory settings running multiple versions of teamviewer but none will work and the T95 running Android 10 has different problems but does not work.
Do you know of any model TV Box I can buy that will run the latest version of Teamviewer Host?
I am haveing the same problem.
Had a few old ones that worked, now cant find one that will.
