How to prevent TeamViewer 15 from turning system sound off
Allan_Dalskov
Allan_Dalskov Posts: 1
edited April 2021 in General questions
Hi
When connecting to to remote computer (Windows 10) and I have computer sounds enabled then TeamViewer turn off System Sounds on remote computer, and don't turn it on again when I disconnect.
How do I prevent Teamviewer from turning off system sounds or make sure when I disconnect the system sounds is turned on again?
Allan
  • SamuelB
    SamuelB Posts: 3 ✭✭
    Hello there,
    Running version 15.12 and having this issue and also the opposite matter of TV ducking the sound on my local computer. I see that this Sound issue is cropping up quite regularly since version 12.
    Is there a clear documentation somewhere explaining how sound works on the local and remote with TeamViewer ?
    My use Case is : I need to have the sound of the remote computer but I DO NOT want TV to duck the sound on my local computer. technically I would like to have TeamViewer on my local computer behaving like a normal sound output and not like a VoIP that request all other local channels to be ducked.
    Best Regards,
  • fstriley
    fstriley Posts: 1
    I see no resolution to this. I have the same problem as SamuelB.
