Privacy when i give remote support
What can somebody find out about me when i give remote support via team viewer.
I just took a quick look. Connections_incoming.txt will show your ID and account name. TeamViewer10_Logfile.log shows the same, but it is not as easy to read. I did not find any recognizable info, computer model, OS version, IP address. It does show the IP address of the TeamViewer server initiating the connection. But like I said, it was just a quick look.
I don't work for TeamViewer. I'm just a user.5
Your TeamViewer ID... That's about it.
If you use file transfer they may see a pop up showing what files were copied.
I don't work for TeamViewer. I'm just a user.1 -
Thank you, he also see the name of my PC, what more he can see?
If you are logged into Computers & Contacts, your account name will be displayed instead of your computer name.
I don't work for TeamViewer. I'm just a user.0 -
thanke you. is it the same in the Log?
