Clear Recent Connections list
You can remove individual connections by clicking "Close" on the right hand side. It would be brilliant to have a "clear all" option though.
Please make it possible to clear the Recent Connections list, and/or to remove individual connections from the list without deleting them from TeamViewer. Thank you.
There is no option to click "Close" on the right hand side. I have a plethora of old obsolete and useless "Devices" that hang around like uninvited guests that won't go away!
Whenever I build a system from an image or change a hard drive or change the WIFI dongle, TeamViewer FORCES a different device, making the old one useless - and I can't make it go away.
TeamViewer - PLEASE - If you're going to make me create new devices causing old ones to be obsolete, then PLEASE allow me to remove the obsolete and useless device CLUTTER
3 -
i have the same issue please fix
Allow DELETE/REMOVE Recent Connections please!!!
