[Windows] v15.47.3
JenW
Posts: 997 Moderator ☑
Operating system: Windows
Version: 15.47.3
Release date: 2023-10-24
New features
- Managed and bookmarked devices are now located in a dedicated section within the Devices tab.
- Support for Remote Terminal sessions is now available in TeamViewer Remote.
- A policy column has been added to the device list. It is now possible to quickly check which policy is assigned to a device and filter based on policies.
- The remove-from-group functionality has been enhanced. It is now possible to select a policy that will be applied to the device after removal.
Improvements
- It is now possible to update devices to a specific version of TeamViewer via policy.
- TeamViewer now includes a new feature called Device Dock, which allows users to always have the device list on top of the screen in a slim user interface.
- Device connection methods are now available through a command bar.
- It is now possible to edit columns on a device list.
Bugfixes
- Minor fixes and Improvements.
Modératrice Communauté Francophone / French Community Moderator
I'm testing the new version! And seeing how it behaves, I just updated but where is the connect button easily accessible?
This was really bad, I went back to the old interface because of this, leave at least one option to enable this!
I need to take a few more steps to do the same thing!
Maison
