Says "Connecting..." but it doesn't Connect
hefn1606
I attempt to connect to my partner computer and it will say "Connecting..." for an endless amount of time, but doens't connect
Just had the same issue, Any idea??
I'm having what may be a similar issue - it sits for a while "connecting", then goes straight to the "sponsored session - buy/rate/ok" dialog, without ever actually giving me a connection to the other end!
(This is going Mac to Mac; the first time I tried, I actually got to the login screen and had about a minute of connection, but every attempt since then has failed.)
