Waiting for server - Login Screen
rstrickhouser
rstrickhouser Posts: 1
Within the past few weeks myself and co-workers are getting "Waiting for server" at the login screen of Teamviewer. We updated to Teamviewer 13 last month and have been using this no problem until recently.  The only way we have been able to fix this is by rebooting our laptops.  I have exited Teamviewer and killed it in task manager with no success.  I was able to reinstall Teamviewer 13 and this worked for that day, but when I return the following morning it has that message when attempting to use Teamviewer.  I changed my password as well just as test and this makes no difference.
Windows 10 Pro
Version 1709 (OS Build 16299.125)
Teamviewer 13
Version 13.0.6447
Updated Dec 25, 2017
Any and all help is appreciated. Thanks!
  • Esther
    edited November 2023
    Hi @rstrickhouser
    This issue looks a bit strange and we need to look deeper into it.
    Thanks and all the best, Esther
  • bellykaud
    I just began to have this issue.  Has a solution been found?
  • Clark_W
    Clark_W Posts: 2 ✭✭
    We are getting this issue as well. Is there any update for this issue?
  • Clark_W
    Clark_W Posts: 2 ✭✭
  • Michna
    Michna Posts: 2 ✭✭
    I have the same problem. TeamViewer 12 Business on Windows. Android apps are working.
  • NenadC
    NenadC Posts: 1
    Same problem paid TV v11.
