How to disable clipboard sync?
Trying to disable clipboard sync.  I've seen some old Internet postings talking about an Advanced setting to disable clipboard sync, but it doesn't appear to be there in newer versions. Any help would be appreciated.  FYI, I am using Ubuntu to connect to a Windows 10 client, if that matters.
- Scott
    JeanK Posts: 7,080 Community Manager 🌍
    Hello @sneader,
    I confirm that in the current version of TeamViewer for Linux, unfortunately, you cannot disable the clipboard sync.
    Best regards
  • Is the clipboard sync feature available in commercial linux teamviewer edition?
  • I checked the ubuntu teamviewer 15.47.3 edition whether to disable/enable clipboard sync is available. But it is not available yet. When is " disable the clipboard sync feature" going to be available?
