Hi
We have windows 10 hp computers that installed teamviewer 15.28.5 version.
When teamviewer getting update and going 15.47.3 it's doesn't working.
It says teamviewer service could not starting.
Anyone can help me ?
We temporarily resolved this issue by installing the older version and turning off updates.
However, this is not the definitive solution.
Also having this exact same issue but with 15.48.4.0.
On installation says the service cant start, loads the login splash screen once and then when closed won't open again.
The following is the event viewer entry for this.
