How do I stop getting the survey at the end of a remote session. THIS IS REALLY annoying becasue it doe snot close by itself it just sits ther I have a lot ao fsession through out the day and I don't want to keep closing this box.
Hi rsgooch,
Thanks for posting!
ZachatCDMS is right in that you can turn it off in the managment console.
This is a feature of the software, the comments go into your connection reports for future reference.
You can also turn this option off by clicking your profile name in the software > Edit Profile > Uncheck the bottom box "Show Comments window after each Session"
-Scotty
I disengaged this by unchecking "Show Comment Window After Each Session" in the management console, under User Management. You might have to do this for every user. Hope that helps!
