Windows 10 Triple Mouse Cursor
Brad1
Having a problem with 3 mouse cursors being displayed when I connect from my Android phone to my Windows 10 PC.
Here's a screen shot: https://imgur.com/a/gaqh3
Both my Windows and Android devices are running the most up to date version of teamviewer. Display remote cursor is not enabled. I have tried adjusting the resolution on both ends and tried changing the DPI settings on the desktop. I'm out of ideas. Anyone else have any for me?
Thank you!
Thank you!
Nevermind. I resolved it. Here are the directions I used:
https://support.corel.com/hc/en-us/articles/115001485408-Display-Options-How-to-change-DPI-Scaling-Level-for-displays-in-Windows-10-Turned on DPI settings through the registry and then manually adjusted the scaling to 149%. 150% still gives the triple cursor issue.
Hi! I have this very same issue. I'm using a 4K display so my zoom is 175%. I could lower it to a number below 150% but that would be just a workaround and I think our friends at TeamViewer should fix this as it only happens on Android. iOS is fine, Windows is fine too.
Here's my cursor:
https://i.imgur.com/BcjyK8a.jpg
Thank you in advance, keep up the good work!0
