Management Console fee use
Dear Sirs, I have been using Google Add-on TeamViewer free and Management console, however, I keep having "Your trial for viewing and checking policies of your devices has expired. Buy a TeamViewer 12 license now.", would you mind to tell me how I can keep using free ? My usage is only for private, not commercial.
  • Scotty
    Hi gordes58,
    Thanks for posting.
    Features such as policies, custom mudules and connection reports are all only included in paid licenses. There is no way to use these features in the free version and if you need these features you would need to purchase a license.
    -Scotty
    Senior Moderator
  • gordes58
    Hello Sirs, thank you very much for your prompt reply, oh, I don't need to use such policyies, custom modules and connection report, only I need to use is to connect to the certain servers , so we can use the basic feature free, I understand now.
    Thank you very much for your great help. Best regard,
