Team Viewer 10 Ubuntu 17.04
agonzaalez15
in Linux only
Hi good day
I am currently working with Ubuntu 17.04 and have problems with the installation of teamviewer version 10, if it operates correctly in this version of ubuntu? , try to install it from the software store without success and by terminal forcing the installation without success.
Dear agonzaalez15,
TeamViewer 10 is supported on Ubuntu 8.04 to 14.04
We do not recommend to use TeamViewer 10 on Ubuntu 17.04.
You may try version 12. It should install and work without issue.
Hope this solution works for you.
Christian
Did my reply answer your question? Accept it as a solution to help others, Thanks.0
