My account is unable to login thru the teamviewer program. And when I login thru the website, I'm able to but there's an error message "An unspecified error occurred. mWXdamKkHdr-3-3-44-WsH"
Can anyone help.. Thank you.
same issue i'm facing
Hi, I am getting the same error, can you advice on a fix please?
still NO solution, OR reply from teamviewer. The problem persists.. almost every day, even after 15.51.6 update.
Teamviewer team> WAKE UP!!!
Any news?
any updates after this??? Apparently i am not the only one having this issue...🤨
i get this message quite regularly on the remote Mac's i want to control, so i can not get in, even though it says the Mac is online. I live in Florida where it is very "normal" that internet goes offline every now and then. So whenever i am abroad in Europe, i can not get in, so have to ask someone to restart the app. Which is extremely annoying!!! The app should restart by itself when there is an error, or at least give an error code, so you can investigate the problem. Also tried to use the old interface, tried several other settings, but no joy! Please HELP! (it used to work fine for years!) Now am looking around for other apps doing the same thing as Teamviewer.
I have is same problem everyday
Hi @donVito,
Thank you for your comment.
Could you please restart TeamViewer, following this gif's instructions?
If the issue persists after the restart, please proceed to the complete uninstallation of TeamViewer from your device and install the latest version from our website.
Let us know how it goes!
Jen
started few days ago
We apologize for any inconvenience.
Our technicians have identified the issue, and a fix has been implemented.
We invite you to follow our status page to get more information: https://status.teamviewer.com
We thank you for your patience and understanding.
hellp please help
an error occured while logging intour account
Also having the same issue.
Can't login to account anymore. Restarted, re-installed. Nothing fixing the problem. Using old interface but I don't see any explanation for why this should stop working.
since today i get this message when i try to connect "an error occurred while logging into your account" whats the problem? I cant open ticket also.
Suddenly started getting this message on OLD interface across multiple devices. Can't login, restarting, reinstalling...nothing works. What is going on? Nothing changed that I'm aware of since this occured.
Same thing here on 2 pc's - online and new interface work but old interface no longer can login
Same here :(( It's lost all my devices and I can't seem to work out how to reconnect
Same here, same message, tried uninstall and install and restart several times, it does not work.
Same as above. "An error occurred while logging into your account". Started around 0930 this morning.
Same here... Other team members are working fine though...
Same with me!!
Update: the same thing happens when I switch back to the old interface, so it is forcing me to use the new one which is useless.
Uninstall (check the remove settings box) and reinstall.
Happened ti me this morning. Uninstalling and a fresh reinstall worked for me.
Same with me
Service Status link: TeamViewer Status
Login Issues
Investigating - We are currently investigating an issue affecting the login services.
Jan 08, 2024 - 10:32 CET
Same here
See they have updated service status now to show these faults
Yeah same issue here for a few of our engineers, plus ones who can get on some of the sites are not accesible
Same 8/1/24 9.38 am
