I have downloaded Teamviewer to my Raspberry Pi (running raspbian).
I installed the armv7-32bit package of the TeamViewer Host.
When I try to login on the application it simply returns "The username and password you entered do not match any accounts on record".
I have checked the credentials are fine, and they work when logging into the webapp on the Pi.
The password is 25 characters long (reduced after following another thread).
I need to be able to add this to my devices to remote into.
