Is there any way to see the history of connections/sessions оn my PC for more than a few days back?
Exanary
Exanary Posts: 2 ✭✭
Hello. I would like to ask please, is there any way to see the connection history to my PC for a few months back? Perhaps there is some file in which the connection log written or some log is recorded. I'm only interested in the date and time of the sessions, no need for many details. I have free license version and Windows 7 SP1. Thank you, I would really appreciate your help.
    Answer ✓
    Hello @Exanary,
    in the path
    C:\Program Files (x86)\TeamViewer
    you will find the file Connections_incoming.txt
    All the logs of the incoming connections will be listed there.
    Answer ✓
    Hello @Exanary,
    in the path
    You are welcome! 😎
  • ph0ng_thanh
    ph0ng_thanh Posts: 1
    I can't find the file name Connections_incoming.txt in C:\Program Files (x86)\TeamViewer
  • poosh52
    poosh52 Posts: 1 Newbie
    In the latest versions, connection logs have been moved to %AppData%\TeamViewer\
    Hi @poosh52,
    If the full client is installed on the remote device, its connection logs are still in C:\Program Files (x86)\TeamViewer.
    However, if the remote device runs QuickSupport to receive connection, connection logs are located as you correctly mentioned in %AppData%\TeamViewer\.
    Hope this helped!
    /JeanK
This Week's Leaders
