Hello, i have a problem on a blackview tablet running android 11.
I'm using the teamviewer host app to remote connect to the tablet running an app in kiosk mode.
I noticed that the teamviewer app doesnt start after the tablet power on but i need to open it manually to be able to connect to it, i did not found an option to make it run on startup.
is there a way?
