Sharing more then 1 screen
dc1
Just curious if there is a way to share more then one screen at a time? If so, how?
Hello dc1,
If you share you're screen and you have more then one screen you automaticly share both screens. I'll show you how you could switch screens.
If you want to switch screens you have to press this button that i point at with my arrow
With kind regards,
Iain Wels,
ICT-Support
If you found this helpfull please verify it as an solution so it could help other people
Iain Wels,
ICT-Support
If you found this helpfull please verify it as an solution, so it could help other people1 -
I do not have that option on my screen.
Hello dc1,
Does the pc you are trying to connect to have 2 screens running and on when you take it over?With kind regards, Met vriendelijke groet,
Iain Wels,
ICT-Support
If you found this helpfull please verify it as an solution, so it could help other people0 -
yes.
