Unattended access free version
Ketelaar
Ketelaar Posts: 1
In the past I clould configure unatted access via the menu, that option seems to be removed.
Computer that had unattended access configured can still be accessed, but the password or accesss can't be changed anymore.
Where did it go to?
    Hello @Ketelaar
    You can still set up Unattended Access on your devices with the free version.
    You will find all the information you need in our Knowledge Base articles here:
    Cheers,
  • Gary_2
    Gary_2 Posts: 6 ✭✭
    Hello Jean,
    Neither of those articles are helpful. The first is about remote control via random password and the second article no longer exists.
    Gary
  • Sifu_Dan
    Sifu_Dan Posts: 1 Newbie
    Correct. I have double-checked this as well. Where can I obtain the manual install for Apple and Windows to allow unattended access? Is it set for a specific password to remote in, or can I change it? Does the password rotate like 2FA, or is the password itself considered 2FA?
    I would like to see what has changed with TeamViewer after not using it for over 10 years, since a company I worked for during that time paid for another service.
    Dan
