IP Access from Home Software
LukasW
Posts: 1 ✭
Hi there,
I am running a PLC software which requires access to IP addresses. Rather than installing the software on the remote computer and logging into the remote PC via TeamViewer and using the program, I was hoping there is a possibility to communicate to these IPs directly from my PC via the remote PC and keep the software on my end.
Does TeamViewer have this capability?
I have this same question still today. There are lots of applications where being able to use a computer as an onsite router (basically) using TeamViewer VPN to use software on a remote PC to support customers would be fantastic!
Thank you for any help and information you can provide.
Joshua
