Saving changes to VIEW tab on the toolbar
When I uncheck the hide wallpaper box in the VIEW tab, it does not save the change. I have to do it each time I connect thru TeamViewer. Is there a way to save those changes permanently?
Bob
  • RickCHodgin
    I would like this feature too.  It's fully annoying to have to go and set this feature every time.
    In addition, other settings should be able to be saved along with the connection, like show remote mouse pointer.
  • edswo58
    edswo58 Posts: 1 Newbie
    I see this thread is 5 years old but never any answer? It is 2024 and I have the same problem
